Which Brand Of Furnace And Thermosat Will Give Me The Most Adjustments - HVAC - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 12:05 AM   #1
Which brand of furnace and thermosat will give me the most adjustments
I need a furnace that is dependable. One that has a variable speed motor and modulating fuel valve 60-80k btu that will run up to 2000cfm.
One that will use any brand thermostat and is fully adjustable using the gas heat or heat pump.
I want to be able to adjust the fan speed when in continious fan on to circulate the cold air in the basement (800-2000cfm)
Adjustable fan speed setting during heat when the fuel valve is 40-100% gas.
Are any brands capable of delivering this.
jlzllc is offline   Reply With Quote
Old 05-28-2012, 12:09 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Not one that will work with ANY thermostat. A communicating proprietary thermostat will allow you to select blower speeds from the stat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-28-2012, 12:23 AM   #3
The rheem rgfg furnace they just installed for me has a modulating non communicating thermostat.
The rheem rep said we had to use a rheem thermostat because we were using a non communication heat pump also.
Does this sound right
Old 05-28-2012, 12:29 AM   #4
AKA HVACTECHFW
It is not a modulating thermostat. Maybe a modulating furnace. No aftermarket thermostat will allow you to select blower speeds. Please give the full model number of the furnace and heat pump.
IT IS WHAT IT IS
Old 05-28-2012, 12:40 AM   #5
Rheem rgfg-06emcks 60k modulating variable speed
thermostat rheem hc-tst412mdms modulating touch screen
heat pump carrier 58gsc065-131gb ( 20 years old )
Old 05-28-2012, 05:42 AM   #6
An old Tradesmen
Rewards Points: 7,384
That Rheem model only has a 3 ton drive, so you won't ever get 2000 CFM of air from it.
Old 05-28-2012, 11:41 AM   #7
I understand the unit installed is incorrect and non adjustable.
I am willing to start over and get it right. I know what i want but need someone to tell me what brand that might be.
Old 05-28-2012, 12:49 PM   #8
An old Tradesmen
Won't find a 60,000 Mod with a 5 ton blower. Might have to use a 100,000 MOD to get a 5 ton blower. Which then sort of defeats having a mod.
None can use any brand of thermostat and then use it to control the blower. the thermostat has to be made for it.
And none let you make more then a minor blower adjustment in heating mode.
