Brain Teaser - HVAC - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 08:05 PM   #1
brain teaser
I was putting on a new thermostat and everything didn't work the way it was suppose to. So I tried 2 other thermostats and wired them the same exact way and got different results for each. How that makes sense I have no idea. For some examples fan on would make me lose power to everything the blower fan inside and outside would never shut off and I would have to kill everything at the breaker when I was done with the air. Its a mess in the furnace wire wise and my buddy and I have been trying to make sense of it all to get this to work with no success. Im ready to call a service tech but im afraid of the bill.
workinmann17 is offline   Reply With Quote
Old 07-03-2011, 08:08 PM   #2
tried 2 digital non programmable t stats
tried 1 dial stat
tried adding a contacter
transformer is getting super hot
tried wiring up just a/c with no heat
fans run to no end
breakers pop
EVERYTIME I DO SOMETHING I GET DIFFERENT RESULTS!!!
HOW?!
Been trying for a few weeks any help to make any sense of this would be a god send.
Old 07-03-2011, 08:10 PM   #3
just looking for someone to post back and stick with me on this one because who ever can solve this one is a genius.
Thanks a million
Old 07-03-2011, 08:16 PM   #4
Rewards Points: 1,574
You need to get the wiring diagram for your a/c, furnace unit. It should detail where the thermostat wires are attached. You also need to make sure thermostat is designed for your type of system; there is no universal thermostat as far as I know.
bob22 is offline   Reply With Quote
Old 07-04-2011, 08:40 AM   #5
Rewards Points: 274
Definately need a wiring diagram. This site may help :
http://high-performance-hvac.com/the...tallation.html
polarzak is offline   Reply With Quote
Old 07-06-2011, 12:19 PM   #6
I have a wiring diagram for the stat and the furnace. There is no diagram for the ac I think it was added in later. The guy who owned the house before me probably did it himself because its a mess. The stat has different wiring options for all systems. I tried hooking it up for both 1 transformer and 2 since theres one for heating a one for cooling.
Old 07-06-2011, 12:23 PM   #7
This issue is something other than the stat its like the stat is sending out its signals and their getting messed up somewhere down the line or just not getting through at all. I truely believe I am missing a part or a relay or something is not wiring down stairs properly but I have tried so many different things I just don't think it will ever be solved.
Old 07-06-2011, 08:05 PM   #8
Take all the low voltage wires off of the thermostat and furnace. Write down what color went where on the furnace as you remove each wire. Then twist two wires together and check the other end for continuity. Continue to check pairs untill all wires are identified. Bet your wires are spliced in a place or two and they change colors.
Old 07-06-2011, 11:38 PM   #9
biggles's Avatar
all furnace power off as stated remove all the wires off the stat subbase write them down colors/letters ....down at the furnace remove the stat wires going in again color/lettering...go out to the condenser and only note the pair of stat wires coming in...typical color for the indusrty is R-Red/hot side tr G-green/Fan Y-Cooling W-Heat C can be any spare.the letter on the stat subbase should be the same color going into the furnace terminal strip...get that far and we will tie in the condenser...
Brain scratcher about how much electric supply I need??? shabba1985 Electrical 19 01-19-2010 08:26 PM
Brain Lock, help a guy out Bigfoot Electrical 13 06-02-2009 09:08 AM
My Brain is Fried! movick724 Electrical 7 06-01-2008 12:35 PM
A new definition to being High-wired: Shark Off Topic 1 03-27-2008 06:50 PM
