BradfordWhite Water Heater Won't Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 02-28-2009, 04:25 PM   #1
BradfordWhite Water Heater won't stay lit
My 5 year old Bradford While water heater will not stay lit. The Blower is working and I am getting good pressure. The pilot lights, followed by the main burner with nice blue flame. After about 90 seconds, it shuts off. If I unplug it, the same thing will happen, but this time the main burner will shut off in about 20 seconds.
Odd thing is, the blue flame starts to turn a little yellow and I get a few drops of water (perhaps condensation? Basement tempature is about 50 degrees.) There is certainly no puddle so there can't be a major leak.
I removed the pilot ignition and sensor (honeywell Q3400A1008) because , but perhaps the sensor is not working. (I don't have a volt meter). It looks clean.
Any ideas?
Thanks,
Mike
mwalla is offline   Reply With Quote
Old 03-01-2009, 05:05 PM   #2
HVAC / Plumbing
Any ideas?
Thanks,
Mike
The water is condensation. Cold water hot flame...I would expect that the valve isn't proving flame. While I'am not familier with this exact mod. With the exception of a few... most All electronic ign. gas equip. must prove flame to stay on
kenmac is offline   Reply With Quote
Old 03-02-2009, 07:43 AM   #3
any possibility the condensation is dripping on the pilot assembly and extinguishing the flame?
kennzz05 is offline   Reply With Quote
Old 03-02-2009, 04:43 PM   #4
HVAC / Plumbing
I have seen that happen. It should correct itself once the water heats up. If it keeps goung out. Then you have other problems . Vent ,valve not proving ignition, Etc, Does this mod. have a vaccum switch ?? If so jump it out & see if burner stays on. Don't leave it jumpet out
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 12:07 AM
Water Heater tsmith Plumbing 10 12-01-2008 06:24 PM
gas water heater testing MrLinux Plumbing 11 04-14-2008 07:07 PM
