Both Led Lights On Circuit Board Flashing On And Off. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 04:05 PM   #1
Both led lights on circuit board flashing on and off.
Lennox 80uhg-75 heating will not come on. Combustion blower come on for about 15 seconds than shuts off. Both led flashing at high rate.
ROBBYROPE is offline   Reply With Quote
Old 09-29-2012, 06:40 PM   #2
Sounds like a control board issue.
Old 09-29-2012, 08:34 PM   #3
Houston204's Avatar
Rewards Points: 556
When you reset power to the furnace and watch it try to start, does the hot surface ignitor ever glow?
Do you ever see it fire up?
Houston204 is offline   Reply With Quote
Old 09-30-2012, 11:06 AM   #4
Reply to houston204
When furnace is reset combustion blower comes on for appro 15 seconds, diagnostic leds [both are continuous on for appro. 3 seconds than go into alternate fast flashing] in appro.3 minutes combustion blower goes thru the above cycle. The hot surface ignitor never comes on.
Old 09-30-2012, 01:09 PM   #5
Houston204's Avatar
Rewards Points: 556
Does the hot surface ignitor have an obvious crack?
Old 10-01-2012, 04:05 PM   #6
Igniter shows no visable cracks. The ohm reading is .68
Old 10-01-2012, 05:58 PM   #7
Should be 14-19 ohms on the Lennox hot surface ignitor.
