Both HVAC Units @ Duplex Went Out Today - HVAC - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 01:02 AM   #1
Rewards Points: 37
Both HVAC units @ duplex went out today
I have a duplex and had both of my tennants call me to say that the air conditioners are not blowing cold. They are completely separate. They are both split systems on seperate meters/panels.
Both of the condensers? are on in the outside. The copper pipe that should be cold was not. I had a roofer installing a roof today and thats the only thing outside of normal.
I have my guy going out tomorrow, but I wondered if this had ever happened to anybody before. I checked the panel and no breakers were tripped. I even went back and double checked w/ volt meter just to make sure all breakers are hot.
sacseven is offline   Reply With Quote
Old 09-21-2011, 06:28 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
roofers probably put nails through the lineset.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-21-2011, 09:35 AM   #3
Rewards Points: 37
Thats what I was thinking. If the nails are 1 1/4, maybe the lineset was installed too close to the roof? Any requirement for conduit?
Old 09-21-2011, 04:18 PM   #4
AKA HVACTECHFW
NO requirement for conduit. If the roofers did hit the lines with a nail they would have known as it would have most likely started hissing.
IT IS WHAT IT IS
Old 09-21-2011, 04:44 PM   #5
Nails flinging off fan blades can get ugly too. Maybe they shut the disconnects off to avoid that and forgot to turn them back on.
Old 09-21-2011, 05:37 PM   #6
Rewards Points: 37
Does this lineset installation look correct? You can see where it touches deck?
Thanks for all the help.
Old 09-21-2011, 06:10 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
Yup, there's a nail through those linesets. I've repaired a few of those. Call your roofer and tell him to be there. those shingles and the wood underneath will have to be cut and lifted, the holes in the lineset brazed close with sodder (yes, it will hold but make sure it's sanded good with sand paper/emory cloth before hand) and then the roof re-repaired.
I think your drain line is cracked as well, the one on the right.
Doc Holliday is offline   Reply With Quote
Tags
air , condensor , hot , hvac , unusual
Ductless Mini Split Install - need HVAC Tech! mike_30319 HVAC 13 03-30-2011 06:18 AM
Old rheem hvac problem Daulton HVAC 16 03-20-2011 12:56 PM
Drastically Different Basement HVAC Instal Costs ... Why? sTiZZiT Off Topic 7 11-27-2010 06:35 PM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
M.i.a.....where is my hvac filter? navarhidas HVAC 4 02-26-2009 11:55 PM
