Boot Register Very Dirty With Interior Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 01-26-2013, 06:37 PM   #1
boot register very dirty with interior insulation
All my supply boots have black insulation on the interior side. The are catching a lot of dust & dirt. A family member has allergies & this dust being able to enter the home is causing problems. Can I remove the insulation so I can keep this area free of dust?
create050 is offline   Reply With Quote
Old 01-26-2013, 06:40 PM   #2
An old Tradesmen
Rewards Points: 6,464
That won't stop the dust. The dust is already in your house. And some may be pulled in through a leaky return system. Fix your return ducts. make suer no air is bypassing your air filter.
Old 01-26-2013, 06:44 PM   #3
Yes, we are checking R/A . Do the boots need the insulation?
Old 01-26-2013, 06:56 PM   #4
An old Tradesmen
Are they in the ceiling. the insulation helps to prevent condensation from forming when the A/C is running. Also helps to prevent heat loss in heating mode.
Old 01-26-2013, 08:47 PM   #5
Yes, they are in ceiling. Is there a foil back insulation or will if I coat them with mastic will that insulate them?
Old 01-26-2013, 08:52 PM   #6
An old Tradesmen
Mastic is not an insulation.
vacuum the dust off of the insulation. And fix the dust problem in the house. All that dust you see on the insulation, is dust that was/is already in your house. And the insulation stopped it from going back into the house.
Old 01-26-2013, 09:04 PM   #7
I checked air handler. The foil back on the insulation has deteriorated & is coming apart. (this is an old house).This seems to be where the dust is coming from. Where do I get replacement insulation for air handler & what is it called?
Old 01-27-2013, 06:40 AM   #8
An old Tradesmen
R4.2 Duct wrap.
Old 01-27-2013, 07:49 PM   #9
Thank you for it help.
Floor Register & Boot Size kmachn HVAC 4 01-16-2012 08:13 PM
Register Boot questionn tee777 HVAC 3 05-06-2009 12:16 PM
Attaching Flex duct to register boot avshockey HVAC 15 12-03-2008 09:07 PM
Proper installation of register boot hartkem HVAC 5 11-15-2008 11:44 PM
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 06:26 AM
