Boosting Air Flow To Second Floor - HVAC - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 04:16 PM   #1
Boosting Air Flow to Second Floor
I want to boost the air flow from my HVAC to the second floor. I have already tried closing vents on the lower floors. Have also made sure that all dampers are open to second floor. In our home the higher you go the hotter it gets.
Will a more powerful blower motor improve airflow ?
Currently have a 1/3 HP blower.
franleck is offline   Reply With Quote
Old 05-30-2009, 04:21 PM   #2
An old Tradesmen
Rewards Points: 7,746
Probably not.
Turn the power off to the furnace.
Remove the blower door.
Hold in the blower safety switch, and have your or some else turn the power back on.
And run teh blower. See if you get more air to the second floor like this.
If so, your return is not enough.
Old 05-30-2009, 04:26 PM   #3
Any tips to improve the return air ?
Thanks !
Old 05-30-2009, 04:36 PM   #4
An old Tradesmen
Need a lot more info.
Size of system. A/C and furnace.
Size of both supply and return duct.
number of supply and return registers, and size of return grilles and supply registers.
To determine what problem the return is having.
Is it the entire duct work. Or just the return drop.
Is it the return registers themselves. or not enough of them.
What type of air filter are you using.
3M makes a terrible air filter if you want good air flow.
Best not to use them.
Old 05-30-2009, 05:51 PM   #5
http://en.wikipedia.org/wiki/Stack_effect
A duct booster fan may redistribute what air you do have.
Old 05-31-2009, 07:53 AM   #6
What about the attic
Franleck,
I have had an old furnace replaced recntly with huge improvements in circulation and with BT's and others advice have improved return air flow on second floor, but you might also want to consider checking your attic for insulation and proper ventilation.
Hot air trapped in a poorly vented attic will radiate down especially with poor insulation. Check out both your rooftop venting and soffit venting as well. Go to www.buildingscience.com to understand how they all tie in. We had our roof redone 1 1/2 years ago, with new venting added prior to the furnace. We saw a huge change in top floor heat buildup, far more comfortable now during summer and proper warmth in winter.
Now I am in the process of upgrading attic insulation and improving soffit venting as well, but venting was key for our scenario One key indicator for me was ice dams forming in the winter.
Chemist1961 is offline   Reply With Quote
Old 05-31-2009, 08:56 AM   #7
I've never had a chance to try this out, but I wired my t'stat controlled attic fan so that it can be switched on in the winter, the idea being that ice dams could be prevented by ensuring that the attic air is the same temp. as the outside air.
Old 06-01-2009, 09:25 AM   #8
sweaty
Rewards Points: 276
In addition to sealing, ventilating, and insulating the attic, try adding a radiant heat barrier to the underside of the roof. That will cool down your top floor in the summer.
sweaty is offline   Reply With Quote
Old 06-02-2009, 09:04 AM   #9
sweaty
Rewards Points: 276
Also, remove the register covers and use foil tape to seal the gaps between your ducts and the drywall. Reach into the duct and see if you can feel seams and/or gaps where pieces of ductwork fit together. Seal those with the tape, also. NOT DUCT TAPE. Do this for the return ducts, too.
On my second floor, I found big gaps in a duct that had very little air coming out. After sealing it, a lot more came out.
This is much more cost-effective than installing new ducts and possibly ending up with the same gaps.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 10:58 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
