Boost Kits.... - HVAC - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 10:23 PM   #1
Boost kits....
Yeah, me again...I'll be here for a while! If hard start kits are so benificial to the system, why are they not installed from the factory??Or is there already units out there with a comparitive...??
Bulldoggish is offline   Reply With Quote
Old 06-27-2011, 11:27 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
some are installed by the factory. Scroll compressors typically dont need them where as recip compressors needed them when a txv was in the circuit.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-28-2011, 12:23 AM   #3
What's the diff between scroll and recip. compressor??
Thanx for the help...
Old 06-28-2011, 05:43 AM   #4
An old Tradesmen
Rewards Points: 6,086
Scroll compressor on left, recip on right.
Old 06-28-2011, 06:46 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
They cost quite a few dollaros $$ so they don't put them on anymore but have them as a add on option. If the unit is to be used in low ambient temp conditions around 50 deg F (usually in a commercial app) then the oil is thicker and one may be required.
Boost Pump for Improved Water Pressure ralphfravel Plumbing 2 08-04-2011 08:33 AM
DIY Outdoor Hardscape Living Kits Made for easy install. Kurtzilla Landscaping & Lawn Care 2 07-30-2010 09:24 PM
Starter tool kits cellophane Tools 16 10-13-2009 03:58 PM
looking into dye kits/ bleach repair kits 4 carpets. any suggestions? flooring Flooring 3 09-02-2008 10:21 PM
soythane sprayfoam kits rodeo Roofing/Siding 4 07-15-2008 12:10 AM
