Boost Air Flow To Bedroom? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-17-2010, 08:22 AM   #1
Boost air flow to bedroom?
My master bedroom is sandwitched between my attic (above) and my garage (and another attic) below. Thus it is the hottest room in the house. To make matters worse, it is the farthest run from our main HVAC stack so there is minimal air-flow. I am looking for a duct fan that I can install to help with this problem. I found an accessible area in the garage, but to my dismay, the duct isn't your standard 4 or 6 inch duct. It is more oval or rectangular, maybe 7 inches or so long by 3 inches wide. (I assume this is because the duct travels between a wall).
Is there a duct fan out there for my problem? Anyone???
Thanks for your time and response,
Mark
Mustng33z2 is offline   Reply With Quote
Old 05-17-2010, 10:52 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
http://www.iaqsource.com/product.php...&category=2160
http://www.iaqsource.com/category.ph...?category=2159
seeyou is offline   Reply With Quote
Old 05-17-2010, 01:08 PM   #3
I'm not sure if that would work because of the small cavity that the duct is in. I am looking for something that I can put IN the cavity.
Old 05-17-2010, 01:20 PM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Did you see the register booster (the 3d option)? Short of those options, you might want to look at more insulation to cut the load down.
Old 05-17-2010, 01:22 PM   #5
Window A/C.
Tags
hvac duct fan
Convert bedroom into a bathroom? ChrisDIY Plumbing 10 04-28-2010 11:04 PM
Master bedroom placement near dining/living room EdieKay Remodeling 0 04-11-2010 07:48 PM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-16-2009 12:09 AM
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
altering HVAC flow levels? joeyboy HVAC 7 05-01-2008 05:22 PM
