Are Bolt Threads An Adequate Ground For A Propane Tank. - HVAC - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 03:47 PM   #1
Are bolt threads an adequate ground for a propane tank.
I have a groung lug bolted to a painted leg of a propane tank. The paint is non-conductive. Are the bolt threads enough to satisfy grounding requirements? Is there a requirement specification for this?
LSquareOne is offline   Reply With Quote
Old 03-08-2012, 10:27 PM   #2
Rewards Points: 1,092
It's probably best to consult your local building department for their code. I would never rely on the threads alone, myself. It's easy to do more than that, so why not?
Old 03-09-2012, 06:28 AM   #3
Just for luck, where a positive ground is needed in open weather, use stainless hardware, scrape the paint off, and use star washers that bite is multiple places.
Old 03-09-2012, 01:09 PM   #4
Good ideas, Bill. I always slap a little bit of grease on grounds, too, including my vehicle battery terminals. Grease MAY be a bit of an insulator (though I doubt it) but it sure beats the H out of corrosion for conduction.
Old 03-09-2012, 01:23 PM   #5
An old Tradesmen
Rewards Points: 6,944
Use a non oxidizing conductive grease, not regular grease.
http://www.sanchem.com/aSpecialE.html
Old 03-09-2012, 05:31 PM   #6
REP
Take what you have and make it better.
What wasn't mentioned is if the leg is grounded to you know,,,,,,,,, the ground
what you don't want around a propane tank is a spark of any knid so any wiring should be bare metal, tight,then you can protect the tight connection with an anti oxidizing grease if you want.
REP is offline   Reply With Quote
toilet tank bolt... mdawson3k Plumbing 7 05-04-2011 12:40 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
Above Ground Swimming Pool Filter Tank twaters12 General DIY Discussions 2 08-13-2007 07:06 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
