Boiler - Zone Valves Stuck Open - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2008, 06:42 AM   #1
Question
I have a boiler with three zone control valves, they are wired in series, with three digital thermostats controlling each. Two, the first and third in the series, are getting stuck open, regardless of what the thermostat is set at - even if it is off.
If anyone can provide me with a wiring diagram, tips, suggestion, ideas, I would greatly appreciate it.
djburns is offline   Reply With Quote
Old 12-30-2008, 04:16 PM   #2
An old Tradesmen
Rewards Points: 7,782
Zone controls are to be wired in parallel, not series.
Old 12-30-2008, 06:17 PM   #3
biggles's Avatar
MARK the ZONE with the room STAT contolling it..wire a zone valve directly to the 24V feed then break one wire by putting thr stat(2 wires) in series....repeat the same for the other 2.the 2- 24V wires feed out R and C to power the zone motors that is parallel and the room stat breaks the 24Vs on one side of the valve with the stat in series.
Old 01-12-2009, 11:00 PM   #4
Thanks for the info, but I need it in layman terms.
There are four wires - red, white, green & yellow.
Pressure switch stuck open? 2 areas im looking @ 1001miles HVAC 42 12-03-2012 03:51 AM
adding 3rd zone to honeywell trol-a-temp system bhelman HVAC 5 03-03-2010 04:11 PM
Bleeding the Air out of boiler without bleeder valves beetlebabs Plumbing 9 12-12-2007 12:37 PM
