Old 08-13-2009, 03:47 PM   #1
WaldenL's Avatar
Boiler Zone Purge Valves - Anything special?
Posted this in plumbing, but i think it would be better posted here...
I'm taking out a run of baseboard in a FHW system so I need to purge the zone. Only problem is the valve to purge it is all shot to hell, I've tried twisting the handle, just twists, no purge. :-) No big deal, I just cut into the pipe and let it drain from the cut. -- Closed all the other valves first.
But, while I have it drained I figured I'd replace that shot valve. I assume, but want to confirm, that a zone purge valve is just a normal valve, yes? There's nothing special about it, right? As it happens the valve is the one on the zone that has the water intake on it.
Thx,
-Walden
WaldenL is offline   Reply With Quote
Old 08-13-2009, 06:57 PM   #2
GC/Master Plumber/Mech
Install automatic bleed valve
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-13-2009, 08:17 PM   #3
Yes it is a regular valve, usually called a boiler drain. I think I would consider a ball valve set up as they are more trouble free.
SKIP4661 is offline   Reply With Quote
Old 08-13-2009, 08:20 PM   #4
Skips right on this one I miss read. Yes a boiler valve.
Totally missed the second paragraph
Old 08-14-2009, 09:24 AM   #5
WaldenL's Avatar
Thanks, that's what I needed to know.
BTW, there are valves other than ball valves?
Honeywell Utica Boiler Valves Question cmariorussell HVAC 2 02-03-2009 10:54 PM
Boiler - Zone Valves Stuck Open djburns HVAC 3 01-13-2009 12:00 AM
Bleeding the Air out of boiler without bleeder valves beetlebabs Plumbing 9 12-12-2007 01:37 PM
