-   -   Boiler Zone Purge Valves - Anything special? (http://www.diychatroom.com/f17/boiler-zone-purge-valves-anything-special-50840/)
WaldenL 08-13-2009 02:47 PM
Posted this in plumbing, but i think it would be better posted here...
I'm taking out a run of baseboard in a FHW system so I need to purge the zone. Only problem is the valve to purge it is all shot to hell, I've tried twisting the handle, just twists, no purge. :-) No big deal, I just cut into the pipe and let it drain from the cut. -- Closed all the other valves first. :)
But, while I have it drained I figured I'd replace that shot valve. I assume, but want to confirm, that a zone purge valve is just a normal valve, yes? There's nothing special about it, right? As it happens the valve is the one on the zone that has the water intake on it.
Thx,
-Walden
Plumber101 08-13-2009 05:57 PM
Install automatic bleed valve
SKIP4661 08-13-2009 07:17 PM
Yes it is a regular valve, usually called a boiler drain. I think I would consider a ball valve set up as they are more trouble free.
Plumber101 08-13-2009 07:20 PM
Skips right on this one I miss read. Yes a boiler valve.
Totally missed the second paragraph
WaldenL 08-14-2009 08:24 AM
Thanks, that's what I needed to know.
BTW, there are valves other than ball valves? :laughing:
