Boiler Water Feed And Aquastat Question - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2011, 09:47 PM   #1
Boiler water feed and aquastat question
Is there any reason why the fresh water feed to the boiler is fed with hot water?
The aquastat shuts the boiler off at 180 degrees and turns it back on at 170 degrees. Isn't that a small temperature swing? Would it help anything to adjust the aquastat to shut the boiler off at 190 or 200 degrees and maybe turn it back on at 140 or 150?
Thanks for the help.
timothy918 is offline   Reply With Quote
Old 01-29-2011, 10:58 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 600
Nope,... Normally it's from the Cold line...
Nope again, as far as I know...
Depending on what your doin' with the hot water, 190+ is probably Too Hot...
I do know 140 is Too Cold to send back to the boiler...
It'll condensate, 'n Rot out the boiler...
Old 01-29-2011, 06:37 PM   #3
The boiler is running a single zone base board heat. I just thought a 10 degree swing in water temperature a little small. And I figured just as long as I didn't turn the aquastat up to where the water hit 212 degrees It would heat the house better.
Old 01-29-2011, 08:04 PM   #4
An old Tradesmen
Rewards Points: 6,470
The hotter the water. The larger your heating bill is. 10 degree swing is common for many aquastats.
Old 01-29-2011, 08:24 PM   #5
Thank you all for the help. I will leave the aquastat alone.
can i fit a motorized valve? stevediy2009 Plumbing 2 11-19-2009 10:45 PM
hot water boiler system - circulator not running hexsprite HVAC 7 01-06-2008 08:55 AM
