-   -   Boiler water feed and aquastat question (http://www.diychatroom.com/f17/boiler-water-feed-aquastat-question-93801/)
timothy918 01-28-2011 08:47 PM
Is there any reason why the fresh water feed to the boiler is fed with hot water?
The aquastat shuts the boiler off at 180 degrees and turns it back on at 170 degrees. Isn't that a small temperature swing? Would it help anything to adjust the aquastat to shut the boiler off at 190 or 200 degrees and maybe turn it back on at 140 or 150?
Thanks for the help.
Bondo 01-29-2011 09:58 AM
Nope,... Normally it's from the Cold line...
Nope again, as far as I know...
Depending on what your doin' with the hot water, 190+ is probably Too Hot...
I do know 140 is Too Cold to send back to the boiler...
It'll condensate, 'n Rot out the boiler...
timothy918 01-29-2011 05:37 PM
The boiler is running a single zone base board heat. I just thought a 10 degree swing in water temperature a little small. And I figured just as long as I didn't turn the aquastat up to where the water hit 212 degrees It would heat the house better.
beenthere 01-29-2011 07:04 PM
The hotter the water. The larger your heating bill is. 10 degree swing is common for many aquastats.
timothy918 01-29-2011 07:24 PM
Thank you all for the help. I will leave the aquastat alone.
