Boiler Vs Water Heater? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2011, 09:30 AM   #1
FlyingHammer
Boiler vs Water Heater?
I'm trying to decide how best to get some heat in my 1500 sf detached garage in Wisconsin. (Best = lowest operating cost.) My goal is simply to keep the building above freezing, probably 40-45F. The PEX is already in the slab, but not hooked up yet. Natural gas is available in the garage.
I've been researching to figure out whether I can use a low-end water heater as the heat source or if a real boiler is worth the extra cost. There seem to be good arguments both ways. I assume the water heater will be somewhat less efficient, but any heat lost will still be inside the building so it may be a wash. I only plan to run it during the coldest 3 months or so if it matters. I plan to use glycol in a closed system (no DHW) so potential freezing is not a concern.
The building is pretty well insulated and it already stays around 30F even with no heat (outside temp between 0 and 10F). There's a 2" polystyrene board under a 6" slab and up the sides. The walls are 2x6, fully insulated, and drywalled. I also put in about 8" of insulation above the drywalled ceiling. All doors and windows are well-insulated and tightly installed.
Any suggestions from the experts?
FlyingHammer is offline   Reply With Quote
Old 02-03-2011, 03:14 AM   #2
KCA
Hello
Hi..
You haven't gotten any responses so I thought that I'd give it a try..
I'm a Plumbing & Hydronic Heating (Radiant) Contractor.
Nothing wrong with using a water heater for the heat source. If the garage is tight a 40 gallon 40MBTU would be fine. 60/40 mix with glycol and away you go.. A slab sensor vrs an air sensing t-stat would be best if still possible.
Any other questions please don't hesitate to ask..
:-) Ken
The K.C. Ament Co., Inc.
KCA is offline   Reply With Quote
Old 02-03-2011, 08:03 AM   #3
DIY staff
Rewards Points: 7,174
Thanks for jumping in----Some times posts get overlooked---this one sure did.
---Mike---
Tags
boiler , efficient , garage , hydronic , radiant
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
should I switch from natural gas to electric water heater supermaxhd Plumbing 24 11-28-2010 12:11 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
How to Shut Off Water Heater From Boiler skittlzski HVAC 2 10-23-2008 07:29 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
