Boiler Troubleshooting - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 07:31 AM   #1
boiler troubleshooting
my boiler will not raise the temperature above 68* I recently drained the system and installed a new safety valve. Ever since then it just won't get hot enough. Yesterday I noticed that the coupler on the circulating pump was broken and I replaced it. I also checked the zone valve and saw that it was 3/4 closed manually so I opened it 100% manually. I immediately felt the difference in the return pipe temperature. It warmed up considerably whereas before it was cold to the touch. I left the system on overnight and in the morning checked and the temperature was only 67* what could be the problem? i also purged the air from the system.
chrislynch is offline   Reply With Quote
Old 02-04-2010, 11:50 AM   #2
yeah this is my 1st time on this site. Thank you for all of your helpful responses!! NOT!!
I retract my hasty comment. I was not patient and in my haste I fear that I may have offended .....Sorry!!
Last edited by chrislynch; 02-05-2010 at 06:27 AM. Reason: realized the error of my ways!!
Old 02-04-2010, 12:49 PM   #3
HVAC Tech/ Browns Fan
It hard to help something like this on here. I work on boilers everyday and it can be trip with them. It sound like you have a air leaking in the system. Is there any pipe look like it or had leak. Even if you replace that part for the pump is the pump getting enough amp draw?
Tator1076 is offline   Reply With Quote
Old 02-04-2010, 02:02 PM   #4
It seems to be working ok now. I shut off the fan and the water started to circulate hot both supply and return side. Then I turned the fan back on and it has been running for 2 1/2 hours. Temp rose from 66* to 71* at last check. I am waiting to see if it continues to rise. Thank you for your help!!! chris
Old 02-04-2010, 03:05 PM   #5
The pump maybe going bad. I bet tonight it will stop heating for you. Do a amp draw on it from start to running on the pump. I always replace the pump if is over 10 years old anyways. I find them runnig slower as time goes on with them.
Old 02-04-2010, 04:47 PM   #6
An old Tradesmen
Rewards Points: 7,414
Hard for people to respond, when they're out working.
Old 02-04-2010, 05:03 PM   #7
Rewards Points: 163
No kidding 4.5 hours? People aren't getting paid here!
52Caddy is offline   Reply With Quote
Old 02-04-2010, 05:52 PM   #8
~beep~Thank you for patiance. We are out servicing paying customers.
Please describe you heating problem and one of our Pros will hurry to the nearest computer to answer your question for free~beep~
hvaclover is offline   Reply With Quote
Old 02-04-2010, 08:39 PM   #9
JohnH1's Avatar
Kind of like being on call at 2:00 in the am. Customer says I called 3 companys the 1st one of you to arrive gets the work. Then I go back to bed.
JohnH1 is offline   Reply With Quote
Old 02-04-2010, 08:54 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
Naw, they call 6 companies. First one to arrive gets the job, other 5 suckers don't get a cancellation phone call.
Old 02-04-2010, 09:03 PM   #11
An old Tradesmen
I beat on the door. And tell them its just like going to McDonalds. Ordering food at the drive thu window and then driving off. You either pay, or get arrested for theft of services.
Then ask them, will this be check, cash, credit card, or the police?
Old 02-04-2010, 10:26 PM   #12
i got burned on one after hours call (guy got our number from the phone book...not a regular).Now I don't do them.
I bet Yuri, Been, and John1 got calls from phone book callers.
If you're an independent you can be sure if a regular calls you you won't get burned.
Old 02-05-2010, 05:54 AM   #13
I want to thank you for asking a question and describing it in such an excellent way so that every one can respond with an accurate answer in a timely manner. " NOT "
SULTINI is offline   Reply With Quote
Old 02-05-2010, 06:24 AM   #14
wow! I must say I apologise for my hasty reaction to a lack of responses. I was VERY frustrated at the time. I have been messing with this boiler for close to a month now and the company owner is breathing down my neck wanting to know why he is cold. As a side note. When I came in this morning the thermostat was programmed to run at 65* over night and the temp is 65* I turned it up to 75* and am going to see if, or how long, it takes to heat up the west lab.
Thank you, A Grateful Maintenance Manager.
Old 02-05-2010, 07:30 AM   #15
Too Short? Cut it Again!
If you do not know what you are doing, get on a service list for someone who knows boilers. The things can be very dangerous. The National Board of Boiler and Pressure Vessel Inspectors was a client of mine for a time. I have mixed emotions about what they do and how they force expensive inspections. My project was to gather clips from all over the country to put in a slide show for elected officials to watch. Half an hour of picture after picture of boiler disasters, almost all because of no inspection and someone not knowing what they were doing in servicing, repairing or bypassing safety devices on boilers. The body parts of kids blown through glass doors when a well intentioned maintenance person started messing with a boiler system he did not understand were pretty dramatic.
Indoor Boiler Question AndrewF HVAC 134 05-13-2011 05:15 PM
Boiler questions mudpaws HVAC 4 06-11-2009 08:22 AM
Outside water boiler shutdown hillardl Plumbing 2 03-20-2009 05:27 PM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 08:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
