Old 11-08-2011, 10:52 AM   #1
boiler temp overshoot
A while back, I noticed that my boiler seemed to be running about 20-25° too hot. With the aquastat set at 180/160, the temp gauge would read about 200-205 (or sometimes even higher) after a burn cycle.
Before resorting to a new aquastat, I tried a couple other things first. I replaced the combo gauge to make sure that it wasn't just reading high. I then pulled the aquastat and temp bulb well to make sure the bulb was fully seated and the well wasn't scaled up or anything. No change - temp was still high by about 20-25°.
As a temporary measure, I turned both controls on the aquastat down by 20° (160/140), and that seemed to work ok most of the time.
I then bit the bullet and installed a new aquastat. To my dismay, even with the new aquastat, the temp still seems to be high by about 10-15°.
A couple questions:
1) Is it worth replacing the temp bulb well? The inside (wet) surface didn't have any scale buildup, but I've since read that over time they can develop a glaze/coating that impedes heat transfer.
2) Is it worth applying heat transfer compound to the bulb & well? I know there are different opinions on this: some say you should always use it, others say don't bother.
Any advice or info will be much appreciated.
johnnyzero is offline   Reply With Quote
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 12:37 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Summer boiler temp question dontilgon HVAC 8 05-07-2010 03:31 PM
What should boiler temp be? Bearcamp HVAC 7 01-19-2009 08:04 AM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 05:21 PM
