Boiler Shutoff During The Spring/summer - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 10:32 AM   #1
Boiler shutoff during the spring/summer
I bought a duplex last year, where the bottom unit (which is rented) is heated by a boiler and the upper is from a forced air furnace. My tenant in the lower unit was commenting on how high his utility bills were, especially the gas. I went down stairs to check the boiler, and low and behold the pilot was lit and is essentially sounded like the boiler was running. I proceeded to turn the gas off and also the electrical supplying the boiler in the hopes that this would lower his utility bills as this is the only appliance in the unit that runs on gas.
If anyone with some HVAC experience could help me out it would be appreciated. I can handle furnace maintenance pretty well by myself, but boilers are something that I do not have much experience in.
dukes32 is offline   Reply With Quote
Old 06-24-2011, 04:42 PM   #2
biggles's Avatar
gas only is for the boiler for that tenent no stove or hot water heater...and if no hot water heater the boiler might be with a Hot water coil within...complaint might be coming there is no hot water
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 11:37 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Height requirement for boiler shutoff switch secutanudu Electrical 2 10-13-2010 07:28 AM
Question about gas boiler shutoff secutanudu HVAC 3 10-13-2010 06:39 AM
