Old 01-06-2013, 07:43 PM   #1
boiler shutdown for off season
Although it's not the off season yet, I have a natural gas, two zone, hot water boiler that is used for winter time only. No pilot light, all electronic ignition. I have a seperate hot water tank for hot water.
Can I safely turn off all power to furnace/zone control switch (emergency red switch/kill switch at top of stairs) or just turn off the t/stat, or both? or just leave everything on during the off season?
Basement is dry and has a dehumidifier in case of humidity over 60%.
I have googled this question and there are a lot of different theroies out there.
Would like to throw this question out to the hvac diy community to see what some of you think about this.
Thanks in advance.
jmon is offline   Reply With Quote
Old 01-06-2013, 07:49 PM   #2
i would shut it off.... not sure why you would leave it on.... someone may have other ideas ...stay tuned
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
jmon (01-06-2013)
Old 01-06-2013, 11:22 PM   #3
how
You can just turn down both thermostats.
Killing the power also works but it may just mean a dead thermostat batteries when it's time to start it up again.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
jmon (01-07-2013)
Boiler pressure valve leaks water on shutdown erockaway HVAC 16 10-15-2012 11:11 PM
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 07:10 AM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Outside water boiler shutdown hillardl Plumbing 2 03-20-2009 06:27 PM
