Boiler Settings - HVAC - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 02:51 PM   #1
Boiler Settings
I have an old boiler from a house built in 1927. I just received my latest bill and it was $400.00. I checked the temp. settings and the high is set to 180 and the low is set to 125. What should this be set at to save money? Also does turning the temperature on the thermostat up and down or even off and on cost more money or not because it's gas? Also what would be my best option for a heat pump?
maslo is offline   Reply With Quote
Old 01-10-2011, 02:59 PM   #2
Experienced
Jackofall1's Avatar
Ouch....$400 leave the boiler on'off settings be, to save $$$ turn the thermostat down.
Heat pump? what state are you in.
Add insulation to the house if you really want to save, sounds like that is what is lacking.
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
Honeywell L8124L Settings on Oil Boiler shawnmd HVAC 1 10-24-2010 07:11 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 06:28 PM
