Boiler Room Venting - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 01:11 PM   #16
An old Tradesmen
Rewards Points: 7,378
Should be from just lowering the low limit temp.
Are you sure you didn't bump the high limit and raise it?
Old 12-07-2009, 03:53 PM   #17
positive.If the temp was higher then 180 would that cause the pipes to make that banging sound
dontilgon is offline   Reply With Quote
Old 12-07-2009, 03:56 PM   #18
An old Tradesmen
Depends how much higher. And what pressure the system was at.
At a low pressure. the water could start to boiler depending how high over 180 it got.
Old 12-07-2009, 04:09 PM   #19
Pressure is 15-18 all the time i look at it. I left it 180-160. Seems to be fine, but my baseboards were always alittle noisy. Sorry but another question, the oil tank has been moved above ground and when they did so(prior owners) the oil line from the tank was 1/2 O.D then went to 3/8 midpoint to the pump. I changed at mid point 1/2 o.d to the pump. Basically its all 1/2 is that OK.Also any clue what BTU this might be, all the labels are worn. The house was build in 90 so it should'nt be that old.
Old 12-07-2009, 05:07 PM   #20
An old Tradesmen
The 1/2" is fine.
Just from the looks I can't tell.
Skylights? Anyone Ever Mix Venting Type with Fixed in same room? nomad943 Roofing/Siding 1 06-25-2009 09:12 PM
Questions for experts. Tech08 HVAC 9 01-25-2009 12:47 PM
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 10:08 AM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
