Old 08-21-2011, 06:23 PM   #1
boiler room exhaust vent
My boiler room gets very hot when the boiler turns on. There is also a slight oder of fumes. I do have a fresh air vent to the outside. My question is, can I add an exhaust fan that turns on with the boiler and works with a timer for a delayed shutoff
vnc72 is offline   Reply With Quote
Old 08-21-2011, 07:41 PM   #2
An old Tradesmen
That would risk putting the room into a negative pressure, and drawing fumes/more fumes from the flue/chimney. How big is the vent to the outside.
Old 08-21-2011, 07:58 PM   #3
The vent is 8" x 16" . I was going to add a seperate vent to eliminate that problem
Old 08-21-2011, 09:22 PM   #4
REP
Do you by any chance live in a 10 story bldg.
If you live in a single family house you might just as well cut off the fuel supply and burn dollar bills instead.
REP is offline   Reply With Quote
Old 08-22-2011, 05:03 PM   #5
Thanks for your input but I,m looking for an intelligent answer to my question
Old 08-22-2011, 05:09 PM   #6
Experienced
Jackofall1's Avatar
I am not 100% sure about what is going on but, if you are smelling fumes are they fumes from combustion, this would indicate that you already have an issue with negative pressure in the room.
How big is your boiler room?
Is there a blockage in the flue pipe of stack?
How well is the boiler insulated? and can you improve the R value of the boiler casing.
Mark
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 11:14 PM
2 clothes dryers exhaust vent icandoanything HVAC 4 11-28-2010 03:21 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
exhaust vent replacement tips KAdams4458 Roofing 4 09-12-2009 04:47 PM
question about cleaning a boiler room Piratehart General Discussion 1 02-14-2006 01:58 PM
