Boiler Replacement-Questions - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2008, 02:04 PM   #1
Boiler replacement-Questions
Hello all, this is my first post to this forum and it looks like there are a lot of good people here.
I am replacing my 20 year old Peerless boiler with a new Burnham unit. I'd like to be able to isolate the circulators in case they ever need to be replaced so I don't have to drain the system. What is the best way to do this? My old system has two circulators mounted on the return side, one side threaded 3/4 pipe and the other 3/4 sweat to copper. I am using Taco circulators if that matters. Thank you.
B
doitformyslef is offline   Reply With Quote
Old 11-03-2008, 03:33 PM   #2
Not-So-Newbie
Not knowing the exact setup you have, take alook at this pdf.
It is typical of a two zone direct system. Always pump AWAY from the boiler (The primary on the return is only for packaging) and isolate the zone valves with full port valves.
If this doesnt address your system, give us more info on your specific system.
http://www.wattsradiant.com/pdf/2ZoneHydrocontrol.pdf
Steven62 is offline   Reply With Quote
Old 11-04-2008, 07:54 AM   #3
An old Tradesmen
Rewards Points: 6,592
Use flanges with shut offs built in to them.
http://www.houseneeds.com/shop/Heati...torFlanges.htm
Old 11-04-2008, 03:23 PM   #4
tk03's Avatar
Rewards Points: 150
See this piping diagram
http://www.comfort-calc.net/pictures...old_Piping.JPG
tk03 is offline   Reply With Quote
Shingle Roof Replacement Questions - Overlay vs Tear-Off /OC vs Tamko tecboy Roofing/Siding 12 06-28-2009 07:09 AM
DIY roof replacement questions FatAugie Roofing/Siding 22 08-08-2007 10:55 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 07:01 PM
