Boiler Replacement, Oil Vs LP - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2011, 04:15 PM   #1
raylo32's Avatar
Rewards Points: 1,252
Boiler replacement, oil vs LP
Friends with an old farmhouse have an ancient oil boiler (that feeds baseboard hydronic units in a 2 zone setup) living in their old dirt floor basement. They are in need of a replacement and are wondering if it would make sense to convert to LP from an operating expense (fuel and maintenance) standpoint. They know they would need to install a bigger LP tank (they have a smaller one for some stoves now) but that is a known quantity.
I don't want to revisit the whole modcon vs cast iron and condensing vs non condensing discussion... although I learned a lot there! The question is merely: in terms of operating costs as defined above for similary sized oil and LP boilers of similar thermal efficiency, is their a major advantage to one fuel over the other?
raylo32 is offline   Reply With Quote
Old 12-05-2011, 04:58 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 996
Ayuh,.... It depends entirely on the local fuel suppliers, 'n their business practices...
Every state, 'n county also have different tax rates on different fuels...
Bondo is online now   Reply With Quote
Old 12-05-2011, 05:35 PM   #3
raylo32's Avatar
I have always been on the gas and elec utilities (city boy) so have no experience with the LP or oil delivery guys. So I guess we can research the cost per gallon (or pound for LP?) for our area (Maryland, Montgomery and Frederick counties). I guess the operating differences must not be all that great then if they are within the wiggle room of local pricing/taxining regimes. Is there an easy reference to compare therms or whatever per unit volume or weight of each type of fuel?
Old 12-05-2011, 05:39 PM   #4
Rewards Points: 756
A couple of things to consider:
Oil has 140,000 btu's per gallon.
Propane 95,000 btu's per gallon.
As you said though, you can cook with propane. If you just want one fuel source then it's the way to go.
You can bury an LP tank. Don't even consider that with oil.
All boilers/furnaces need maintenance but it's usually cleaner with gas vs oil.
FYI - around here LP is about $1.30 a gallon cheaper than oil, depending on your contract. Western MA.
Personally, I just went from oil to propane (and the modcon) and don't regret it one bit.
AandPDan is offline   Reply With Quote
Old 12-05-2011, 05:44 PM   #5
REP
In this day and age you cannot count on either fuel coming down in the future.
The really big differance in the two is that durning the year oil will tend to soot even if its only a little and this soot will insulate the fire from the sections so that at the end of the year your effiency is totally differant than at the start of the year and that is if you had a quality cleaning to start with.
You don't get that build up with propane or natural gas.
Now if the conversation is about cost of operation then I will say there is little that can be more benificial than sizing it exactly right.This might cost a little to do right but you end up with the benifit for 20 or more years.
Next would be having a outdoor reset installed when the boiler is installed.
An indirect water heater and a Spirotherm air elimination air scoop would also be included in any install I would normally do.
Being able to isolate the zones,the boiler,the circulator pumps,the water heater and any other items in the system with ball valves will pay for itself on the first trouble call.
Good luck
REP is offline   Reply With Quote
Old 12-05-2011, 05:50 PM   #6
raylo32's Avatar
Thanks, I thought oil had a higher energy density but didn't have the #s handy. I didn't want to raise the modcon issue, since it generated such controversy last time! But that is what I am going to recommend to them. I don't think (at least couldn't find) a modcon oiler so that may make the fuel choice moot. Then it will depend on their timeframe to stay there and the cost deltas. Also may be some install issues to consider like old chimney vent may need work even to go with another mid-efficiency oiler. So maybe just as well to get a condensing boiler and run a cat IV vent. I know there is a lot of boiler expertise here so more to come if/when we have more questions.
Old 12-05-2011, 06:02 PM   #7
raylo32's Avatar
Thanks for the tips, REP. Spirotherm looks like good gear. My friends are getting quotes from oil company this week or next and then maybe from gas guys. I'll pass this along to them for info.
Good luck
Old 12-05-2011, 06:57 PM   #8
An old Tradesmen
Rewards Points: 6,836
LP, with a good mod/con boiler with outdoor reset.
Old 12-05-2011, 07:07 PM   #9
raylo32's Avatar
I thought you might say that. :-) If it was my $ that's what I would do, too. Interesting to see how this one develops....
Old 12-11-2011, 12:09 AM   #10
011010100110111101100101
Rewards Points: 160
Wha?
I'm in Southern NH, and it's about that much HIGHER than oil!
-- Joe
anesthes is offline   Reply With Quote
Old 12-11-2011, 06:42 AM   #11
Hvac Pro
yuri's Avatar
Rewards Points: 1,760
need to REALLY check that carefully. is there not some hidden costs like tank rental and delivery charges that add up also? I guess there is a delivery chg for oil but maybe it is higher for propane? not sure if you can buy your tank or maybe it is cheaper to rent?
do they have a reputable mod con boiler installer AND servicetech. those are quite complicated and if the local guys are only good at oil or better at it then getting proper service and parts is a huge problem in rural areas.
Old 12-11-2011, 08:16 AM   #12
Rewards Points: 756
Just like any fuel, you need to shop around.
I found prices that varied by about 60 cents a gallon. Some included delivery fees, "environmental recovery fees," and others, rental fees.
In my case, as long as I buy more than 250 gallons a year, the tank fees are waived. No other fees.
Old 12-26-2011, 07:02 PM   #13
Rewards Points: 28
Not so, joe
Originally Posted by anesthes View Post
Wha?
-- Joe
I also live in southern NH (Hollis) and checked the price of propane with our local supplier just the other day. We currently use propane only for cooking and it's true that at $4.19/gal it is more expensive than heating oil at $3.59.
However, if we install a propane heating system, the price of LP propane will drop to $2.92. This is obviously a huge difference.
As has been written a zillion time on this and other forums, propane has only 2/3rds the btu's as oil does, so it's more expensive per btu... But it can be burned more efficiently, which helps close the gap.
Amazer98 is offline   Reply With Quote
Old 12-26-2011, 10:39 PM   #14
Rewards Points: 160
Originally Posted by Amazer98 View Post
I
That is based on usage however, correct?
I only use about 100 gallons of oil per year as we primarily heat with wood (it's free). So I imagine I wouldn't be in a bracket that would receive a discount for usage.
Who quoted you $2.92 ? I'm in Salem.
-- Joe
Old 12-27-2011, 09:50 AM   #15
Rewards Points: 28
-- Joe
Yes, for sure, with propane the price depends on the annual amount you buy. Lorden Oil and Propane quoted me the current $2.92 price, based on at least 1200 gal/yr. Eastern Propane was something like $3.30 for the same quantity! If I buy somewhat less than that (like 1000-1200 gallons... Not sure what thelower threshold is), the price jumps to $3.02 with Lorden.
I wish e could pay what they do in Kansas... Something like $1.88! But that's a steep price for having to live on the prairie...
boiler sight glas replacement problem PontiacPaul HVAC 2 10-29-2011 05:09 PM
steam boiler need replacement techsavy HVAC 2 02-28-2011 05:29 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Cost of boiler & cylinder replacement abaminog Off Topic 9 03-31-2010 07:05 PM
Steam boiler replacement mindcandy30 HVAC 3 12-10-2009 02:13 PM
