Old 10-31-2008, 11:06 AM   #1
hvaclover's Avatar
boiler question from a warm air guy
Some body helped a scorched air only tech here. Boiler temp has to stay a certain temp to be ready for a heating cycle
I think a hot water boiler's standing temp is like 130F*, yes?, no?
And the aqua stat keeps the boiler water from falling below the 130*F set point. Now my question is are gravity systems still being installed (IE. heating loop in the floor for the whole home.
Now if this system is still used does an aquastat till maintain water temp when no heat is actually being called for or does the burner only turn on during a call for heat
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 10-31-2008, 06:42 PM   #2
I have gas!
Clutchcargo's Avatar
My boiler doesn't maintain a low heat point. It cycles between 140° and 180°F only when the tstat is calling for heat.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-31-2008, 07:15 PM   #3
Custom Cabinet Maker
Most hot water system boilers set for 180. aqua stat maintains the temp stat actually run zone valves and circulator , at least that is how I understand it.
skymaster is offline   Reply With Quote
Old 10-31-2008, 07:33 PM   #4
My boiler doesn't have a low cut-on. I think only boilers that provide heating for domestic hot water maintain a minimum temperature. When there is a call for heat my boiler cuts off at 180 and on at 165. When it's real cold outside I'll bump the high limit up to 190-200.
jerryh3 is offline   Reply With Quote
Old 11-01-2008, 06:56 AM   #5
An old Tradesmen
If the boiler is providing domestic hot water by tankless coil. Maintaining temp is required.
If by indirect, if it is a high mass boiler, you need to maintain temp, if its a low mass, you don't have to.
Some guys like to maintain temp, to prevent condensation in the boiler from cold starting.
Primary secondary piping can provide the same protection in some applications.
Others need a tempering loop.
Always follow manufacters return water temp guides.
Many boilers don't do well with 20 to 30 minutes of 90°F return water temp.
Old 11-01-2008, 11:25 AM   #6
hvaclover's Avatar
Old 11-01-2008, 12:25 PM   #7
An old Tradesmen
LOL...
Which part is confusing.
Old 11-01-2008, 01:16 PM   #8
hvaclover's Avatar
The part where a pinhole in a super heated steam line can cut a guy in half
Old 11-01-2008, 06:23 PM   #9
An old Tradesmen
Atleast there is no bleeding when that happens.
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 10:01 AM
Ring Main Question Andyjr Electrical 5 09-14-2008 10:47 PM
Question on Refilling / topping off Weil McLain Boiler memovox2 HVAC 4 02-01-2008 11:05 AM
Boiler Shut Down SassySue General Discussion 3 01-01-2008 12:49 PM
question about cleaning a boiler room Piratehart General Discussion 1 02-14-2006 01:58 PM
