-   -   Boiler Question regarding Pilot Relite Control & Ignition Electrode Assembly (http://www.diychatroom.com/f17/boiler-question-regarding-pilot-relite-control-ignition-electrode-assembly-134692/)
stevepatts 02-22-2012 08:42 PM
I have a late 80's model Utica boiler and the automatic ignition won't come on to ignite the pilot. I am able to manually light it when the thermostat cycles on and it will operate until the thermostat cycles off. I think that the issue is the Pilot Relite Control (White Rodgers) and/or the Ignition Electrode Assembly. I disconnected the Ignition Electrode Assembly where it connects at the Pilot Relite Control and noticed that the wiring connected to the harness was severed. This could have been when I tried to remove the wire or just that it was worn out - can't tell by inspection. My question is this - if I reconnect the wire to the harness and re-attach it to the Pilot Relite Control - should that correct the problem or do I need to replace both the Control and Assembly? I would prefer to replace only the part(s) that need replacing. Or - is that not my problem at all (though I think it is). Any help would be greatly appreciated. Thanks in advance.
