Boiler Question - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 03:25 PM   #1
Boiler Question
I have a
Sears Roebuck Model# 229-962171 SER. NO. 1D711
It's pretty old prob about 20+ years.
Quick question.
Can the heat exchange on it be replaced? I had a guy quote me $5000 for a new system because the heat exchange is clogged.
sphelps is offline   Reply With Quote
Old 01-12-2009, 03:58 PM   #2
Yes, probably not cost effective though.
SKIP4661 is offline   Reply With Quote
Old 01-12-2009, 04:04 PM   #3
It can be done though?
My wife just called and said a second guy says I can't be..I just want to know if it can be.
I can understand cost efficient...but just tell me that ya know.
Old 01-12-2009, 05:41 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,650
Ayuh,..
Considering that the Heat Exchanger part of a 20 year old Boiler makes up about 95% of the Boiler....
No,... You Can't.... The Heat Exchanger IS the Boiler...
Old 01-12-2009, 06:04 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 180
Usually they can be cleaned. Messy and expensive. The serial # may indicate 1971 so it may be an old beast. Probably very inefficient. A newer high efficiency one will pay for itself quickly.
Old 01-12-2009, 07:25 PM   #6
An old Tradesmen
Rewards Points: 7,830
Should be able to clean a boiler.
Its an annual thing on oil boilers. And oil furnaces
Old 01-12-2009, 10:07 PM   #7
You must have a hot air furnace. as long as your duct work is in good condition just get the new furnace but 5000 seems a little high get a second opinion
thelimit is offline   Reply With Quote
Weil-Mclain boiler question Boiler1 HVAC 1 12-28-2008 11:25 PM
Boiler to forced air question tmbrink HVAC 6 12-08-2008 04:11 PM
boiler question from a warm air guy hvaclover HVAC 8 11-01-2008 05:23 PM
Question on Refilling / topping off Weil McLain Boiler memovox2 HVAC 4 02-01-2008 10:05 AM
question about cleaning a boiler room Piratehart General DIY Discussions 1 02-14-2006 12:58 PM
