Boiler Primary / Secondary Loop - HVAC - DIY Chatroom Home Improvement Forum
Old 08-12-2010, 03:41 PM   #1
Boiler primary / secondary loop
I am in the process of replacing a 30+ year old hot water boiler (oil) with a gas boiler. The current system has a single zone that runs the entire house. I'm reading a lot about primary / secondary piping, but can't find any details as to if it provides any value when there is only one circuit. it seems to me that with only one loop there would be no need for a primary / secondary setup. Any thoughts?
cruxop is offline   Reply With Quote
Old 08-12-2010, 07:42 PM   #2
An old Tradesmen
Rewards Points: 7,826
On radiator systems. When you install the new boiler. It allows you to set up the boiler to have the water flow it needs. And the heating loop with the higher or lower water flow it needs.
Old 08-13-2010, 07:22 AM   #3
so you are saying i should still pipe it for the primary and secondary, even though there is only one heating loop?
Old 08-13-2010, 02:59 PM   #4
An old Tradesmen
Yes.
Was your new boiler sized to the homes heat loss. Or the size of the radiators.
Tags
boiler , primary loop , secondary loop
Indoor Boiler Question AndrewF HVAC 134 05-13-2011 05:15 PM
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
Taco IFC pump makes noise when it stops Addicted HVAC 21 04-14-2009 12:59 PM
Weil-Mclain boiler question Boiler1 HVAC 1 12-28-2008 11:25 PM
Boiler Primary Loop Choices Mike Warner HVAC 7 07-16-2007 10:01 AM
