-   -   Boiler Primary Loop Choices (http://www.diychatroom.com/f17/boiler-primary-loop-choices-9893/)
Mike Warner 07-14-2007 08:26 PM
1 Attachment(s)
I'm installing a 110,000BTUH condensing boiler,
with an indirect fired domestic water heater. This
is a closed system with a jacketed indirect-fired
hot water tank. Ascii characters for Tee's and 90 elbows.
Which is the best primary loop design of these five?
The boiler is not shown but is at the top, with three
connections for DHW out, Sys return, and Sys supply.
An attached text file shows the piping configurations.
Any thoughts/opinions are much appreciated,
Mike Warner
RippySkippy 07-15-2007 07:50 AM
From your description, it sounds like a Weil-McLain unit...am I close? I couldn't open your ascii art file. I just finished a 155 with a 36 gal indirect, I know I don't have all the answers...but I'd willing to help out.
See if you can re-work your ascii file, maybe take a screen shot and post the jpg or bmp.
MechanicalDVR 07-15-2007 12:48 PM
Assuming that this is a residential job, pipe the water heater to have the priority loop and control of the boiler. This is easily done so that the water heater takes priority over heating demand when it needs to make hot water, it usually only takes a few minutes to bring the heat exchanger up to temp.
Mike Warner 07-16-2007 01:12 AM
1 Attachment(s)
I'm attaching a picture of my friends system, which corresponds to the first of the five choices in the previously attached text file. I'm wondering if the other four primary loop configurations are any improvement over my friend's working system. Which of the five primary loops in the text file attached in the first post would seem to have the best flow characteristics?
I may post another attachment of a "paint" file with just colored arrows if that would make the other four primary loop configurations more understandable if anyone requests it.
Thanks for the replies so far!
Mike Warner
Mike Warner 07-16-2007 01:22 AM
System components
Hey Rippy Skippy, The boiler is a Triangle Tube Prestige Solo 110, and the indirect fired water heater is a Triangle Tube Smart 60.
Mike
Mike Warner 07-16-2007 03:07 AM
This is the color replacement for the text file.
1 Attachment(s)
Working with "Paint" and "Irfanview".
Hope these clear up my question about which of these five primary loops is best.
Mike Warner
RippySkippy 07-16-2007 07:34 AM
From the drawings and my un-professional opinion, I don't think you're altering your flow all that much with any design. I think it's most important to follow the directions and size your pipes correctly. Many times you have to work with what fits your install. Watch the details for example on the W-Mc, the primary loop return legs had to be less than 12" little things like that can trip up a system.
Sorry I can't be of more help.
Mike Warner 07-16-2007 11:01 AM
Primary Loop
Hey RippySkippy,
Same on the Solo110 boiler, the primary loop legs need to be 12" or less.
Your response and that ofMechanicalDVR were helpful.
Thanks,
Mike
