Old 10-15-2012, 10:37 PM   #16
Boiler pressure valve leaks water on shutdown
All good information. I have another quote coming tomorrow for the conversion. After that I'm going to try just about everything here.
Also just confirmed a very minor oil leak on or near the supply line. It's very small but concerning.
erockaway is offline   Reply With Quote
Old 10-15-2012, 11:11 PM   #17
NOTE: If you have cast iron sectional boiler with clean out plugs, do not over torque trying to remove for checking/cleaning waterside the sections will crack under too much stress...try to remove pipe caps or pipe nipples or drain connections to gain whatever access you can at least for initial assessment.
techpappy is offline   Reply With Quote
Hot Water Heater Problems Btabach Plumbing 7 05-21-2012 02:24 PM
Is 15psi on boiler too low? vcsolit Plumbing 13 04-18-2012 11:34 AM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
