Boiler Pressure Relief Valve Leaking - HVAC - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 05:58 PM   #1
Boiler pressure relief valve leaking
I have a residential oil fired boiler with a relief valve set at 30 # and the pressure on the boiler reads 13#. Is this simply an old valve or could there be another issue? Its a slow leak . A drip every 6 seconds . Any advice would be appreciatted.
Thank You
Jason
Jaschance is offline   Reply With Quote
Old 02-08-2010, 07:10 PM   #2
An old Tradesmen
Rewards Points: 6,480
Expansion tank is probably full. And relief valve did its job. But is worn enough that it can't close.
Drain tank and replace relief valve.
Old 02-08-2010, 07:52 PM   #3
DIY staff
Rewards Points: 7,174
Been there---What he said!
Old 02-08-2010, 11:05 PM   #4
Thanks for your replies. The valve between boiler and expansion tank was leaking as well. I was able to tighten the valve and it stopped leaking. I will replace the pressure valve tomorrow.
thanks again
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 05:49 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
