-   -   Boiler pressure relief valve leaking (http://www.diychatroom.com/f17/boiler-pressure-relief-valve-leaking-63943/)
Jaschance 02-08-2010 04:58 PM
I have a residential oil fired boiler with a relief valve set at 30 # and the pressure on the boiler reads 13#. Is this simply an old valve or could there be another issue? Its a slow leak . A drip every 6 seconds . Any advice would be appreciatted.
Thank You
Jason
beenthere 02-08-2010 06:10 PM
Expansion tank is probably full. And relief valve did its job. But is worn enough that it can't close.
Drain tank and replace relief valve.
oh'mike 02-08-2010 06:52 PM
Been there---What he said!
Jaschance 02-08-2010 10:05 PM
Thanks for your replies. The valve between boiler and expansion tank was leaking as well. I was able to tighten the valve and it stopped leaking. I will replace the pressure valve tomorrow.
thanks again
