10-17-2010, 10:43 AM
#1
Boiler pilot light working, but no heat
Thank you in advance for any advice. In the past I've had problems with no heat, but it was because the thermocouple needed to be replaced and the pilot wouldn't stay on. Today, the pilot is fine, but when I turn the thermostat on...no heat. I am a complete newbie when it comes to things like this, so any simple advice of what I can do? Dumbing it down, in this case, would be a good thing. Thank you!! Deirdre
10-17-2010, 10:59 AM
#2
Hvac Pro
Is the power switch turned on? Post some pics of the boiler and burner so we know what you have.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-17-2010, 11:22 AM
#3
Make sure the gas valve is on "main" not just "pilot".
If you don't stand behind our troops, please feel free to stand in front of them.
10-17-2010, 11:34 AM
#4
Yes, I just checked and it is "on". I'll try to post some pictures. Thank you.
10-17-2010, 11:36 AM
#5
Yes, the gas valve is on "main" and not "pilot". I can't figure out what the problem is, it seems like everything is working like it should. Thank you.
10-17-2010, 11:52 AM
#6
An old Tradesmen
Do you hear the circulator run when the thermostat is calling for heat? If not, you may have a blown fuse, tripped breaker, or someone may have turned off the burner emergency switch at the top of the stairs.
Could also have an open roll out switch.
10-17-2010, 12:09 PM
#7
Beenthere...Thank you. No, I don't hear the circulator run when the thermostat is calling for heat. The burner emergency switch is "on". Can you tell me how to check for a blown fuse or tripped breaker, please? Are those something I could probably fix myself? I was able to change the thermocouple by myself, by following directions on the internet. I'm just trying to save money, if it's something I can figure out. Thanks, again.
10-17-2010, 12:13 PM
#8
An old Tradesmen
For the breaker. Look in your electrical panel box to see if the boiler's breaker is in the on position like all the other breakers.
Look to see if there is another on off switch at the boiler that has a small extension on it. If so, there should be a fuse in it.
10-17-2010, 12:40 PM
#9
Beenthere...I just noticed the green indicator light on the boiler, that shows when the damper is open, is not lit. Would this have anything to do with the problem?
I'm going to check the breaker and check for a blown fuse. Thank you very much for your advice.
10-17-2010, 12:44 PM
#10
An old Tradesmen
Could be that the damper isn't working, and it needs to be manually opened, until you replace it. Or if no other lights are on either. It can be an indication of no power to the boiler.
10-17-2010, 01:52 PM
#11
Beenthere....THANK YOU so much! I think it was just the circuit braker needed to be reset. The light is on and I have HEAT! Thank you so much for your time and patience. Deirdre
10-17-2010, 02:21 PM
#12
An old Tradesmen
Your welcome.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
