Boiler Pilot Is On But No Heat, Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 01:57 AM   #1
Boiler pilot is on but no heat, problem
i got some major problem here .im not sure if i check evrything but when i turn my boiler yesterday did not have heat got my pressure of 14 psi ,my pilot light is on last winter is just working fine did nothing to it just put down the thermstat to low . i need your help guys its geting cold and the wife is complaining
popoy is offline   Reply With Quote
Old 10-31-2011, 07:01 AM   #2
biggles's Avatar
hot water boiler for baseboard or steam boiler? if you have a temperature controller on either (down on the boiler) cycle the dial ccw/cw and reset to the temp it was at.if you have a digital stat do you have lit LED/temp readings....shows you have 24Vs present emergency switch on the side of it is ON or at the top of the stairs is UP
Steam heat Boiler burns, steam doesn't travel? tomhere HVAC 18 10-16-2010 03:01 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
pilot light on crown aruba boiler mazzonetv Plumbing 1 05-28-2009 10:13 AM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 09:11 PM
Heat Pump + Aux Heat Problem - Can You Help? whitedavidp HVAC 17 12-25-2008 06:37 PM
