Boiler Outdoor Reset Control - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 01:29 PM   #46
tk03's Avatar
Rewards Points: 150
Your boiler should not run until there is a demand than stop when the demand from the Tekmar ends. If your control does not maintain temperature all the control of the boiler is from the Tekmar. The Tekmar demand or no demand id from the thermostat. The Tekmar will control the water temperature from the heating curve which is determined by the settings for OD air high and low and boiler water temp high and low.
tk03 is offline   Reply With Quote
Old 03-03-2010, 02:03 PM   #47
Just call me Andrew
Rewards Points: 1,020
Sorry....having a little trouble understanding what that all means...
Andrew
secutanudu is offline   Reply With Quote
Old 03-03-2010, 02:25 PM   #48
An old Tradesmen
Rewards Points: 6,906
An outdoor reset is wired in series with your boiler controls, temp control circuit.
So that it can stop the call to the burner, so the burner only runs if the outdoor reset circuit is closed.
Its call an outdoor reset. Because it "resets" the boilers temp(high limit temp) by the outdoor temp.
The Following User Says Thank You to beenthere For This Useful Post:
secutanudu (03-03-2010)
Old 03-03-2010, 02:30 PM   #49
Just call me Andrew
Oh, so it goes between the aquastat and the burner?
It must have two thermostats, right? One inside on the boiler and one outside?
Andrew
Old 03-03-2010, 02:42 PM   #50
An old Tradesmen
Yes, it has 2 temp sensors.
Depends on aquastat and burner as to how its wired in.
Old 03-03-2010, 02:57 PM   #51
Just call me Andrew
Great, I understand now. Is this something I could easily install myself? I am familiar with electrical work, not boilers so much.
I have an oil-fired Weil McLain boiler from about '94.
Andrew
Old 03-03-2010, 03:07 PM   #52
An old Tradesmen
There not hard to install and set up.
Just don't make a mistake and wire it that it bypasses the boilers aquastat's high limit.
MUST be in series.
Old 03-03-2010, 03:09 PM   #53
Licensed Master Plumber
Both Tekmar's and Taco's web sites have the wiring diagrams for just about every situation you could come up with. BTW, Tekmar manufactures the same control for Taco. There are other makers out there as well like the Beckett Heat manager.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 03-03-2010, 03:15 PM   #54
An old Tradesmen
Which is a joke. And a knock off of other manufacturers control scheme.
Beckett even admits. that at a bout 20 outdoor temp, the HM doesn't do anything to save you money.
Old 03-03-2010, 03:38 PM   #55
Hey !!
Now it makes sense to me too
I'm probably going to wait until we get a new heating system installed
Until then I will reset manually once (if) it warms up here
Old 03-03-2010, 05:35 PM   #56
what you want is a Buderus boiler with the logamatic control.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
New Tekmar 256 Reset Control: Boiler Minimum Temperature? VelvetFoot HVAC 0 12-17-2009 11:32 PM
S9301A1001 Integrated Boiler Control Invisible-Man HVAC 3 03-31-2009 09:49 PM
Wiring limit control on gas boiler uncleneiler HVAC 2 11-21-2008 01:54 PM
Wiring limit control on gas boiler uncleneiler Electrical 1 11-21-2008 08:03 AM
