Boiler Outdoor Reset Control - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 04:56 PM   #31
An old Tradesmen
Rewards Points: 7,356
All of those are low voltage wires.
The line voltage wires for your circ. Are inside the junction box that control is mounted on.
Old 01-20-2010, 05:10 PM   #32
Licensed Master Plumber
www.taco-hvac.com has all the wiring diagrams for their stuff
www.tekmar.com has the same thing
honeywell's site also
NHMaster is offline   Reply With Quote
Old 01-20-2010, 06:09 PM   #33
Joe F's Avatar
Rewards Points: 294
I understand that I have line voltage being controlled by low voltage. Does the circ pump wiring need to be separated? I don't see a provision on my ZVC for line voltage control. Only line voltage on the ZVC appears to be the power supply to the unit.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 01-20-2010, 06:25 PM   #34
An old Tradesmen
Yes. the line voltage of teh circ has to be removed from the relay of the boiler.
On your ZVC. You should have main end switch, extra end switch.
Use the main end switch to control circ. And the second end switch to operate boiler.
Or. if you use the Weil McLain BCP, or Tekmar.
The main end switch tells the BCP, or Tekmar it has a heat call. And the BCP or Tekmar turns on the circ and boiler.
Witch control are you going to use. Its easier if we only talk about one outdoor reset control for wiring.
Old 01-21-2010, 06:40 AM   #35
Joe F's Avatar
Rewards Points: 294
When I remove the circ from the boiler relay, I'll need to add a pump relay (SR501) into the system correct? As far as wiring, I'm looking at the Tekmar D256. If I'm reading the schematic correctly:
ZVC Main end switch connects to the Tekmar (boiler demand). Tekmar goes out to the boiler.
ZVC second end switch connects to the circ relay (SR510) and then line voltage out from the 501 to the pump.
Old 01-21-2010, 10:01 AM   #36
I am totally no expert. Maybe you are making this more complicated than it is. I just recently added a 256 to an Argo-controlled boiler. My case was more complicated because I wanted to use priority for the domestic hot water and had to add a relay. I downloaded the picture below from the web and have no connection or approval or whatever from the originator, but it helped me.
VelvetFoot is offline   Reply With Quote
Old 01-21-2010, 10:42 AM   #37
Joe F's Avatar
Rewards Points: 294
I'm sure I'm making it more complicated than it is .
Old 01-21-2010, 01:02 PM   #38
An old Tradesmen
No you wouldn't have to, the outdoor reset control has its own built in relay for that.
But. My head is in left field this week.
All you have to do with the reset control is have it break the orange wire from the relay center on your boiler to your high limit on your boiler. That will shut the burner down, but allow the circ to stay running.
Old 01-21-2010, 01:36 PM   #39
Joe F's Avatar
Rewards Points: 294
The second end switch from the ZVC would be the input to the reset control?
Old 01-21-2010, 01:40 PM   #40
An old Tradesmen
Yes. That will tell it that there is a heat call.
Old 01-21-2010, 01:50 PM   #41
Joe F's Avatar
Rewards Points: 294
Thanks!! My wife will be so excited to see me tearing into the heating system again!
I'll let you know how it goes.
Old 01-22-2010, 10:00 AM   #42
tk03's Avatar
Rewards Points: 150
Sure would have been easier to do the Taco ZVC-EXP control and just plug in the Taco PC700 OD reset control to the ZVC panel.
tk03 is offline   Reply With Quote
Old 01-22-2010, 11:39 AM   #43
Joe F's Avatar
Rewards Points: 294
I agree it would be simpler. I came up withh a cost difference of $300 between the Tekmar 256 and the ZVC/PC700 combo. I'd also wind up replacing a 1 year old ZVC-404 with a ZVC-404-EXP. Kinda hard for me to justify.
Old 02-28-2010, 10:31 PM   #44
Found this chart as an example of reset control Temps
Not sure if it is accurate at all
Old 03-03-2010, 09:26 AM   #45
Just call me Andrew
Rewards Points: 1,020
I read this thread and still don't understand how an outdoor reset can lower the temperature of your boiler water...if the aquastat is set for 160/180....how does the reset prevent it from turning on when the water drops 1o 160?
Maybe this is a related question....why is it called a "reset"?
Andrew
secutanudu is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
New Tekmar 256 Reset Control: Boiler Minimum Temperature? VelvetFoot HVAC 0 12-17-2009 11:32 PM
S9301A1001 Integrated Boiler Control Invisible-Man HVAC 3 03-31-2009 09:49 PM
Wiring limit control on gas boiler uncleneiler HVAC 2 11-21-2008 01:54 PM
Wiring limit control on gas boiler uncleneiler Electrical 1 11-21-2008 08:03 AM
