Originally Posted by Beronicles
Is the flame sensor the same as a rollout switch?
The flame sensor is a thin metal wire that will be in the path of the pilot flame. It will have a ceramic sleeve around it where it mounts in the assembly. There will be a lone wire coming from it going down to the control board. Sometimes these can be gently pulled out of the assembly to clean them. A scotchbrite pad or steel wool is recomended to clean them. In a pinch I have used a dollar bill to clean them.
A rollout switch is a round button like device about the size of a nickel with two wires attached to it or it will look look similar to that with a "U" shaped wire sticking up from it.
I had a boiler guy come look at it and he seemed to think it was the gas valve. He was going to have to order the part so I wanted to see what you all thought first. Thanks again.
I think your boiler guy needs to get some training
