Boiler Not Filling - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 07:22 PM   #16
An old Tradesmen
Rewards Points: 8,178
Bladder may be bad.
Old 12-09-2010, 07:23 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 396
Go to HDepot and for $25 you can get a powerful halogen construction work light (yellow with stand) as we need LOTS more lighting and detail to help you.
Old 12-10-2010, 04:20 PM   #18
So am I right though? The bottom half of the expansion tank should be very warm if it's functioning properly? After work tonight I'm planning on draining the system and getting a pressure read on the expansion tank. Hopefully I can just swap out a tank, or correct the pressure on this one if it's off.
andrewhharmon is offline   Reply With Quote
Old 12-10-2010, 06:32 PM   #19
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,... The way your's is plumbed, yes, the bottom will have water in it, 'n air at the top...
No need to pull the tank to check/ set the pressure...
There's a schrader valve under that little blue cap...
Old 12-11-2010, 11:30 AM   #20
Ok, took the best video I could. Not great.
http://www.youtube.com/watch?v=LeM1b...e_gdata_player
Again I'm assuming it's the expansion tank. I check the pressure with a tire gauge and it didn't even move the gauge. I know that tool isn't very sensitive, but it should have registered 12psi.
What are my next steps to troubleshoot the tank?
Thanks.
Old 12-12-2010, 06:59 AM   #21
An old Tradesmen
Pressure can't be set with it attached to/subject to system pressure.
Old 12-12-2010, 07:00 AM   #22
An old Tradesmen
Thanks.
Get new tank. Yours is too old to mess with.
Tags
backflow valve , boiler , fill valve , hvac
Low water cutoff keeps shutting boiler off dolfish HVAC 7 12-06-2010 04:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 06:28 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
