Boiler Knocking - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2014, 06:59 AM   #1
Rewards Points: 12
Boiler knocking
I have a boiler heating system with a gas furnace. It had galvanize pipe but the leaked real bad. Was told that I could replace the leaking pipes with copper, so I did. But now it knocks really loud. Really loud. How do I stop the pipes from knocking??
Delvia Carter is offline   Reply With Quote
Old 12-05-2014, 07:09 AM   #2
Boiler knocking
Have you got circulation through boiler?
gassyplumber is offline   Reply With Quote
Old 12-05-2014, 07:15 AM   #3
Rewards Points: 12
Boiler knocking
How do I know if I do or dont
Old 12-05-2014, 07:53 AM   #4
Boiler knocking
Is your pump switched on? Or is boiler just making popping sounds ? Bleed air possibly from piping
Old 12-06-2014, 10:09 PM   #5
how
Rewards Points: 728
Boiler knocking
Check your gauges for what your operating pressure and temp when the boiler is running and thumping..
The noice can be from anything that restricts the water flow (a gate valve still turned off, air block, pump not working) or from a blown exp tank.
Is the noice coming from the boiler or the runs.
how is online now   Reply With Quote
Old 12-08-2014, 08:34 PM   #6
Rewards Points: 12
Boiler knocking
Is there any thing I can put in the water to free up the restriction??
Old 12-09-2014, 01:10 AM   #7
how
Rewards Points: 728
Boiler knocking
No!
Can you answer the last post about the operating temp & press?
Old 12-10-2014, 05:58 PM   #8
Rewards Points: 12
Boiler knocking
PSI was at zero. But now have another problem. A pipe busted and when it was removed it was clogged with black corrosion.
Old 12-10-2014, 11:40 PM   #9
how
Rewards Points: 728
Boiler knocking
You sound way over your head there.
A PSI of 0 with the boiler firing can really do some major damage.
It sounds like you need a plumber to replace the leaking pipes, refill the system, bleed the excess air, get the PSI up to 12 PSI so that he can test your system to see if any other pipes are clogged.
Old 12-11-2014, 06:21 AM   #10
Boiler knocking
I am mot a plumber, but a boiler which is behaving as yours maybe dry firing. Blocked pipes indicated years of neglect. If a boiler is allowed to leak over the years, the oxygen in the make up water will cause corrosion. I agree with others you need a professional to look at it. You need more than pipe replacement. Some pictures might help others asses the situation.
jimn01 is offline   Reply With Quote
Suspect Electric boiler causing brownout crankcase Electrical 4 11-06-2012 02:41 AM
New Boiler for an Office - Got Two Quotes, but What Do We Need? Prolow Plumbing 0 09-17-2012 07:10 AM
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 12:37 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
