Old 02-02-2009, 11:50 AM   #1
Default Boiler keeps shutting off
I have had a 2 month problem of my Weil-Mclain Gold boiler (Oil, forced hot water) shutting off and needing to hit the reset button for it to start back up. I've had the boiler guy out about 4 times, each for the same issues, and it is still happening. I've spent 1k on it so far. He has replaced the electrodes, the nozzle, filter from the oil tank, replaced old piping that was encased in concrete with more modern tubing, replaced the temperature control valve, and replaced the fuel pump. It continues to shut down and I think the boiler guy may be in over his head, and I do not want to spend a dollar more without it actually getting fixed. Anyone here ever have this issue before?
cosgrojo is offline   Reply With Quote
Old 02-02-2009, 12:44 PM   #2
An old Tradesmen
You need a service tech that knows how to work on oil burners.
There are people that are very goo with the hydronic side of boilers.
But, they can't work on the burner side.
Did this guy use a tester to check the combustion efficiency.
By doing so, the test will tell you how well it is or isn't burining and lead him to the problem in most cases.
It sounds like your using a parts changer, not a service tech.
Old 02-02-2009, 12:58 PM   #3
Thank you for your input, I will mention it to him when he comes back today.
Old 02-02-2009, 05:10 PM   #4
An old Tradesmen
What did he fine.
More On This Topic
Basic maintenance is vital to the long-term use of any motor vehicle. With the price of fuel and the cost of experienced technicians on the rise, the need for many cyclists to perform scheduled maintenance themselves and conserve their riding budgets has... Read More »
Hi this is David from The Big Easy Catering Company in Santa Barbara California for expertvilliage.com. Today we are doing chocolate fountain we are to the point now that we are going to be doing the double boiler that is going to melt the chocolate for... Read More »
Hi, my name is Nate McCullough on behalf of Expert Village. In these clips were going to talk about the proper way to remove or replace an engine valve cover that is cracked, excessively worn, rusted out or otherwise defective. In this clip were going to... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Hi, this is Karen from Expert Village. Now, I am going to show you how to make a spider web cake. For this we will need six ounces of chocolate or chocolate chips, a quarter cup of margarine, and two tablespoons of corn syrup all in a double boiler pan... Read More »
Need Help I Have a BOILER PROBLEM mikerouse1989 Plumbing 7 02-01-2009 07:07 PM
Boiler Troubles *I Need Help Please* mikerouse1989 HVAC 4 02-01-2009 01:59 PM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 10:48 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 10:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 06:21 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
