Boiler Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 05:15 PM   #1
Boiler issue
My boiler system will start up just fine and heat the room as it should. Problem is that once the thermostat reads that the setpoint temperature and ambient are the same, it shuts the pilot light off. After ambient drops below the setpoint temperature the system won't light the pilot which obviously won't light the main burners. However, if I turn the boiler power off and then turn it back on(manually with a switch), it will fire right up and do exactly what its supposed to do. Any help would be great.
Edit: If helpful, its a Weil-McClain HE-3, Series 2
ajlboarder is offline   Reply With Quote
Old 11-11-2011, 05:37 PM   #2
Rewards Points: 616
boiler is locking out for some reason. you are re-setting it when you turn the power on and off ,,,,,,
carmon is offline   Reply With Quote
Old 11-11-2011, 05:59 PM   #3
I think the relay on the pressure switch is defective... it kicked on when I put a jumper across
Old 11-11-2011, 07:59 PM   #4
An old Tradesmen
Rewards Points: 6,544
Or you have an obstruction in your flue, or moisture in the hose, a crack in the hose, A restriction in the boiler.
Old 11-11-2011, 08:53 PM   #5
Rewards Points: 616
i concure could be many things
Old 11-13-2011, 11:57 AM   #6
If any of these were the case, why does it work properly on start-up? Seems like some component based defect to me..
Old 11-13-2011, 02:34 PM   #7
An old Tradesmen
Because its a partial obstruction. And gets worse as the unit runs. then when the unit shuts off, the obstruction is still causing the problem. Its probably not satisfying the thermostat completely, and is locking near the end of the heat call.
Old 11-13-2011, 05:14 PM   #8
I can drop the setpoint manually to satisfy and the problem still exists even after only 1 minute of running.
Old 11-13-2011, 05:22 PM   #9
I have also noticed the following:
If thermostat is on and set to higher than ambient before boiler is turned on -> system works fine
If boiler is on before thermostat is set to "heat" -> system has the same problem (blower kicks on but wont light pilot)
Old 11-13-2011, 06:34 PM   #10
An old Tradesmen
probably needs a good cleaning and service.
Old 11-13-2011, 07:22 PM   #11
how
Rewards Points: 1,102
If you bypass the thermostat leads and fire it through a heating cycle, does it still lock out?
how is offline   Reply With Quote
Trying to wire Honeywell IAQ to Burnham RSM/96 oil boiler 6burgh HVAC 26 11-13-2010 09:21 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Why does my oil boiler maintain heat? secutanudu HVAC 5 10-19-2010 04:46 PM
Outside water boiler shutdown hillardl Plumbing 2 03-20-2009 06:27 PM
Boiler Troubles *I Need Help Please* mikerouse1989 HVAC 4 02-01-2009 12:59 PM
