| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Phase Distortion Plug-In for Logic Pro
by Expert Village
The next plug-in is phase distortion. Phase distortion is going to combine phasing modulation as well as distortion at the same time. Now when looking at our inserts, the first thing we can do is choose the phase distortion by going into the distortion... Read More »
Using the Moog Voyager Touchpad for Analog Synthesizers & Keyboards
by Expert Village
My name is Dan Rapport. Today we are going to be talking about analog synthesizers. So one very unique feature of the mini Moog Voyager is the touch screen here, which works on an XY axis and it is pressure sensitive as opposed to how hard you push on it... Read More »
Compressor Problems with a Car Air Conditioner
by Expert Village
Hi, my name is Mark Delgado with American Auto Service for Expert Village. The compressors can have problems with the electrical devices that turn the clutch on. A lot of times you'll hear the clutch kick on when the air conditioning clicks on and off... Read More »
What are the Uses of a Reciprocating Saw
by Expert Village
Hi, my name is Ed Reyes with Master Builders here in Tampa, Florida and I am representing Expert Village. We are going to show you how to use a reciprocating saw properly. There are different reasons why we use this particular reciprocating saw. In... Read More »
Checking Gasket to Change Fuel Pump
by Expert Village
Hi my name is Jeff Fiffie. I'm showing you how to move and replace a fuel pump on a Lincoln Continental. The first thing you want to check is your oil ring, checking it very closely to make sure there's no dry rotted. There's more cases when you receive... Read More »
