Boiler Ignitor - HVAC - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 08:29 PM   #1
Boiler ignitor
I have a Weil McLain CGM-5 boiler that has developed a leak in the line that supplies propane to the ignitor. Does anybody know the part # for what I need?
Northstar9126 is offline   Reply With Quote
Old 06-18-2010, 11:47 PM   #2
as seen on tv
Rewards Points: 150
1/4 and 1/8" tubing is a generic part and could be purchased at any supply house or may be a hardware store
qbert is offline   Reply With Quote
Old 06-23-2010, 03:33 AM   #3
You need 1/4 inch aluminium tubing and new compression fittings for connection to gas valve and pilot assembly.
hvaclover is offline   Reply With Quote
Old 06-23-2010, 06:32 AM   #4
An old Tradesmen
Rewards Points: 6,470
Pilot line kit.
Indoor Boiler Question AndrewF HVAC 134 05-13-2011 06:15 PM
Oversized boiler solution (radiant heat)? gbwillner HVAC 5 02-14-2010 07:28 PM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 09:48 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 09:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 05:21 PM
