BOILER HELP (making Decision) - HVAC - DIY Chatroom Home Improvement Forum
Old 01-19-2011, 02:54 PM   #1
BOILER HELP (making decision)
Hello,
I am new to this forum, I see that there are lots of helpful information posted. I am hoping that someone can advice me correctly.
Here is my issue:
I have a current Pensotti R-4 boiler that I am looking to get replaced because of age, plus I had problems with the low water sensor (there was no water in the boiler). The repair tech that came out said that I needed a new guage, new low water vavle, and possibly a new burner.
I started getting estimates from various companies: The prices range from $4900 to about $6500.
The current setup is, I have in-direct hot water with 2 zones. I am being quoted either a Peerless WBV-03 or a Burnham MPO 115.
My question is, which is the better boiler, what is the difference between the two, should I replace the hot water tank the same or can it wait, and finally around what price range should I be looking at just to replace a 2 zone, in-direct hot water boiler?
Any help would be GREAT!!! I am tota
lenonh is offline   Reply With Quote
Old 01-20-2011, 03:40 PM   #2
An old Tradesmen
Rewards Points: 7,814
What ever price they charge in your area.
Only contractors in your area can know what to charge.
Both boilers are good boilers, the Peerless WBV has been around longer then the Burnham MPO.
The indirect can be changed out at a later date if it fails.
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
Low water cutoff keeps shutting boiler off dolfish HVAC 7 12-06-2010 04:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Boiler making high pitched persistant noise liverpoollass Plumbing 2 12-04-2009 04:25 PM
tough decision need help choosing boiler mynd66 HVAC 3 11-23-2008 07:31 PM
