Boiler Heating Zone Not Working Properly - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 08:52 AM   #1
Boiler heating zone not working properly
I have an 18 month old PurePro Trio boiler with the Trio Energy Manager Plus. Forced hot water heat. Priority is OFF.
zone 1: hot water tank
zone 2: 1st floor heat
zone 3: 2nd floor heat
Zone 1 works fine.
Zone 2 works fine.
Zone 3 has trouble. When it calls for heat, the zone pumps water, but the boiler will never kick in as it cools down. If zone 3 is the only one calling for heat, it will pump and pump until the boiler gets cold. As soon as another zone calls for heat, the boiler will then fire up just about immediately.
Any ideas on what I could do to fix this?
Thanks!
ssevern is offline   Reply With Quote
Old 12-19-2009, 09:32 AM   #2
Remodeling Contractor
put your hot water onto its own zone and turn on priority which will feed the water heater and the boiler will reheat as needed. Then move zone 3 which is not working to zone one.
Old 12-19-2009, 10:32 AM   #3
An old Tradesmen
Rewards Points: 7,816
Zone one of that control is the priority zone.
Priority can be turned off or on.
Old 12-19-2009, 03:46 PM   #4
Mainah's Avatar
is the trouble zone on it's own relay control?
if so it needs to be wired to the aquastat to fire the boiler, either thru TT or ZR, depending on how the other zones are wired.
Mainah is offline   Reply With Quote
Old 12-19-2009, 05:50 PM   #5
thaks everyone
Thanks for the pointers... I'm going to check everything and make sure this zone is connected just like the others... if so, then I will try to move things to zone 4 instead... perhaps something is wrong with 3.
Water heat is already its own zone. I don't see a need to turn on priority - usually we never get low on hot water or anything, and the boiler is plenty large enough for this house... Any reason I SHOULD turn it on?
Old 12-19-2009, 06:05 PM   #6
An old Tradesmen
If your boiler is over sized, no.
Tags
boiler , heat , purepro , trio , zone
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Hot Water Heating Problem....please help gor4200 HVAC 6 01-24-2011 01:17 AM
Zone 1 not working properly doug galloway HVAC 3 12-14-2007 05:18 PM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 06:04 PM
