Boiler Goes Thru Its Normal Start Up But Wont Fire - HVAC - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 05:40 PM   #1
boiler goes thru its normal start up but wont fire
can anyone help me out with this boiler goes thru its normal start up but doesnt fire. have plenty of oil i opened the inspection cover and there is oil in the fire box but doesnt fire?
abazzanosr is offline   Reply With Quote
Old 11-02-2011, 07:21 PM   #2
An old Tradesmen
Rewards Points: 6,060
Oil in the combustion chamber that hasn't been burned, will make for lots of smoke in the house, to say the least.
Could be the nozzle is spraying a bad pattern, or that the ignition transformer is bad. or the electrodes out of adjustment, or carboned up.
Might want a fire extinguisher beside you when you try to run it again. Oil can go boom.
Old 11-02-2011, 08:44 PM   #3
Rewards Points: 582
yes oil will go boom..be very careful with fuel in the chamber if small spark happens boom in chamber as beenthere said and i agree ignition transformer may not be working common problem. some oil burnners have fuse link ?? some carbon up again common problem ...how old is furnace and what make???
Old 11-03-2011, 07:58 AM   #4
Rewards Points: 1,214
Open up chamber and light a piece of paper and burn the unburnt oil laying in there before troubleshooting. Only press red reset button once if it don't fire call for service do not keep pushing the reset I know from experience I'm still cleaning soot and smoke out of my eyes,nose, ears, mouth 40 years later. You need to check the oil pressure and spark.
COLDIRON is offline   Reply With Quote
Need help fast please re hydronic boiler water supply and backflow DanDaMan Plumbing 21 12-22-2010 08:01 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
Furnace won't fire, exhaust fan hot and won't start tex800 HVAC 14 10-08-2010 07:48 PM
Cold weather is here, looks like time to start a fire Scuba_Dave Off Topic 78 10-03-2010 11:21 PM
Propane tank was empty boiler does not start schrubber HVAC 3 12-30-2008 05:36 PM
