Old 01-23-2011, 10:55 PM   #1
Boiler gas valve question
The water pressure reducing valve sprung a leak today and water got on to the gas valve. Now the pilot light goes out after the boiler aqua stat cycles a few times. It isn't going out on any consistent pattern. Is it possible the gas valve is bad from getting wet?
If the gas valve ends up being bad. Where can I purchase one?
Thanks for the help.
timothy918 is offline   Reply With Quote
Old 01-24-2011, 11:23 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,... Anything is Possible, 'n it's probably the valve...
Google should answer Where to get 1...
Old 01-24-2011, 09:21 PM   #3
An old Tradesmen
Wet gas valve=replace gas valve.
Boiler blowing pressure relief valve alecmcmahon HVAC 1 10-18-2010 06:52 PM
Power Vent Question for Propane Boiler Moondaddie HVAC 4 12-23-2009 08:12 PM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
central heating boiler leacking from relieve valve ladybreaker Plumbing 3 01-07-2009 01:37 PM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 11:09 PM
