Boiler Expansion Tank Placement - HVAC - DIY Chatroom Home Improvement Forum
Old 10-15-2011, 09:40 PM   #1
Question
boiler expansion tank placement
I have an older 20 to 25 year old Weil McLain boiler. I had my house broken into and they stole my copper plumbing. I replaced all the plumbing but I don't know where the expansion tank goes. It looks like the order is - on the inlet side, shut off valve, pressure regulator then tee into the boiler and on the other side of the tee the expansion tank. There is no other inlet available on the boiler. I was told the expansion should be on the return, but the boiler is piped in black pipe, the inlet was all copper. I don't see any other place to install the tank. If it makes any difference, all the radiators have automatic air relief valves. I don't have any zones. Any help would be appreciated.
pooh is offline   Reply With Quote
Old 10-16-2011, 04:31 AM   #2
An old Tradesmen
Rewards Points: 6,860
Just before the circulator.
Old 10-16-2011, 06:57 AM   #3
Mark Potter's Avatar
Rewards Points: 150
Can you provide picture?
Mark Potter is offline   Reply With Quote
Old 10-16-2011, 07:02 AM   #4
raylo32's Avatar
Rewards Points: 1,252
Holy crap! I've heard of this happening to homes under construction but not like this. Did the thieves at least have the courtesy to shut off the main water supply valve? Are you replacing with copper or CPVC?
raylo32 is offline   Reply With Quote
Old 10-16-2011, 07:46 AM   #5
Rewards Points: 150
Yup this is a very common problem lately with Copper and aluminum there getting ballsy and Taking it from people who have been living for years it's just not newly built houses.
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Thermal expansion tank placement downunder Plumbing 19 06-08-2010 08:47 PM
Installing a new boiler expansion tank CoachDad HVAC 0 01-06-2010 01:12 PM
Where to find an old boiler expansion tank? jrdamien HVAC 1 12-01-2009 07:08 PM
how to install a expansion tank to a gas boiler iris Plumbing 2 10-08-2008 02:17 PM
