Boiler / Control Valve Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2014, 05:38 PM   #1
Boiler / Control valve problem
I have had an ongoing problem that I am stumped with. I have a Valiant gas fired, hot water radiator, cold boiler with 2 zones operated by one Taco 007 pump and two Taco 570 series zone valves. Both zone valves operate properly 95% of the time. Then there are the times when one calls for heat and the other does not but both run. When this happens I physically close a ball valve so I do not waste money. I have replaced one of the Taco heads because the small blob on the switch had broken off so the contact was not working. The other looks to be ok, blob is fine, wax solidifies when not calling for heat. I looked at the way Taco says 2 zones should be wired but mine looks nothing like this. Before I go tearing it apart and really muffing things up I want to get other opinions.
If you tell me how to post pics I have sketched out the wiring and have pics of the controls.
Scott
spb180 is offline   Reply With Quote
Old 02-12-2014, 06:50 PM   #2
MarginallyQualified
Rewards Points: 2,464
Before I go tearing it apart...
Press the "QUOTE" button below.
In the next window look for the paperclip icon.
Press it. Then follow the prompts.
Old 02-12-2014, 06:57 PM   #3
Rewards Points: 282
apb180, welcome to the forum. You may get better results if you ask this in the hvac forum. Maybe a moderator will repost your question for you. They will do it for you. Thanks.
Post some pics when you can. As far as posting pics, many different ways you can do it. Click on quote button, click the insert image icon. Hold your mouse over it till you find the right one, or go to manage attachments in additional options follow prompts and add your pic. Thanks.
jmon is offline   Reply With Quote
Old 02-12-2014, 07:19 PM   #4
Rewards Points: 282
[FONT=Times New Roman]I have had an ongoing problem that I am stumped with. I have a Valiant gas fired, hot water radiator, cold boiler with 2 zones operated by one Taco 007 pump and two Taco 570 series zone valves. Both zone valves operate properly 95% of the time. Then there are the times when one calls for heat and the other does not but both run. When this happens I physically close a ball valve so I do not waste money. I have replaced one of the Taco heads because the small blob on the switch had broken off so the contact was not working. The other looks to be ok, blob is fine, wax solidifies when not calling for heat. I looked at the way Taco says 2 zones should be wired but mine looks nothing like this. Before I go tearing it apart and really muffing things up I want to get other opinions.
There are different ways to plumb and wire your situation. You simply may be missing or not have the right zone switching relay or you have a switch going bad. Just a guess at this point.
Before you go taking things apart, post pics of everything and start there. Stay tuned, best to wait for beenthere or yuri to respond. They are busy, please give them time to respond. Thanks. Sorry I couldn't be of more help to you. Hope you get your system working the way you want and save money.
Old 02-12-2014, 08:24 PM   #5
An old Tradesmen
Rewards Points: 7,378
Yep, post pic, or post a description of how they are wired.
Boiler Question regarding Pilot Relite Control & Ignition Electrode Assembly stevepatts HVAC 0 02-22-2012 08:42 PM
need help finding a selenoid actuated ball valve to control "circulation line on HWH tominator Plumbing 1 03-29-2011 09:46 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Gas Boiler Problem HChu Plumbing 5 10-22-2010 04:25 PM
Need Help I Have a BOILER PROBLEM mikerouse1989 Plumbing 7 02-01-2009 05:07 PM
